Before collecting the Connection Client logs on the client, enable debugging first, then reproduce the issue.
Enable Connection Client Debugging
Update/create the following Registry key on the client's computer. The Debug value is of type String:
[HKEY_LOCAL_MACHINE\SOFTWARE\Digital River\ConnectionClient]"Debug"="True"
Location of the Resulting Logs
On the client computer, the resulting logs will be located in the folder C:\Users\<username>\RDP6\Logs.
Disable Connection Client Debugging
On the client's computer, update the following Registry key:
[HKEY_LOCAL_MACHINE\SOFTWARE\Digital River\ConnectionClient]"Debug"="False"
