You can have your software saving the files to \\tsclient\webfile folder.
Than the files will appear to the end-user as a browser save dialog, with his local drivers only.
HYML5 - how to create a specific and constant web folder path? Print
Modified on: Mon, 19 Jul, 2021 at 2:37 PM
