You can have your software saving the files to \\tsclient\webfile folder.
Than the files will appear to the end-user as a browser save dialog, with his local drivers only.
HTML5 - how to create a specific and constant web folder path? Print
Modified on: Fri, 14 Oct, 2022 at 11:50 AM
