The Virtual Printer doesn't work in HTML5.
To use the Virtual Printer you need to use either:
- a TSplus generated client,
- mstsc.exe or any other RDP client,
- the RemoteApp connection client from the web portal.
Modified on: Sun, 14 Jun, 2020 at 11:22 PM
Send feedback
