To reset the TSplus AdminTool PIN code / password, proceed as following::
- open a registry editor by clicking on execute / regedit,
- then locate the following registry key : HKLM\Software\DigitalRiver,
- delete the admp key and save.
You can also directly edit this registry entry to modify the PIN code.
