- in HTML5 mode, you cannot bypass the previsualization.
However, if you use the redirection, then the printer selection window will show up automatically.
- in RemoteApp mode or using a Generated Client (.connect), you can send directly a print job to to the user's default printer (if the local discs are shared)
