You will be able to shadow your remote session by using the session manager located in the admin tool | server tile instead of the task manager.
Only server and pro version of Windows will support this feature.
For Windows server, if you wish to remove the consent for shadowing a session you can use this group policy :
  1. Open Group Policy Editor (Gpedit.msc) on the server that is running TSplus.
  2. Under Computer Configuration, expand Administrative templates, expand Windows Components, and then click Terminal Services.
  3. Right-click Sets rules for remote control of Terminal Services user sessions, and then click Properties.
  4. Select the Enabled option.
  5. Under Options, click Full Control without user's permission.
  6. Click OK, and then quit Group Policy Editor.
To update the local policy immediately afterward, go to a command prompt and run the following command:
gpupdate /force
For Windows 10 Pro, if you wish to remove the consent for shadowing a session you can use this group policy :
gpupdate /force
