First of all, check the power settings on client and server side, they are usually at cause.
You can set up a timeout for disconnected sessions which will cause a disconnected user session to automatically logoff after a while.
Open your domain strategy object editor (gpmc.msc) and locate the following strategy :
  • Either solutions should work, choose the one that fits your preference.
If you are experiencing this issue with the HTML5 web client, edit the settings.js file with notepad located in C:\Program Files (x86)\TSplus\Clients\www\software\html5
and modify the W.send_logoff = true parameter to false.
