You can set up a timeout for disconnected sessions which will cause a disconnected user session to automatically logoff after a while.
- open your domain strategy object editor (gpmc.msc) and locate the following strategy :
 You can also make sure your domain controller do not prevent local strategies to be executed.
- this strategy needs to be disabled and is located in :
 If you are experiencing this issue with the HTML5 web client:
- edit the settings.js file with notepad located in C:\Program Files (x86)\TSplus\Clients\www\software\html5
- and modify the W.send_logoff = true parameter to false.
Please note that if your TSplus server has joined a Domain, then TSplus disconnected sessions rules don't apply.
