You need your firewall to let TCP / UDP
443 / 80 / 3389
ports opened for ingoing and outgoing traffic.
These are the IP addresses to open at the level of software and hardware firewalls:
93.88.241.55 :     License / telemetry
51.254.22.117 :   Updates
83.166.153.206 : TSplus compatibility updates / Check for updates / View changelog
These are the URLs to allow for updates:
setup.dl-files.com
dl-files.com
secure-download-file.com
