This Remote Access documentation indicates how to perform a backup : https://docs.dl-files.com/tsplus/advanced-backup-database/
However Remote Access can't backup the Windows users and groups you have created.
TSplus will only backup your TSplus configuration.
To migrate Windows accounts, we recommend using a tool like CopyRight2.
Web Credentials are backed up, and the information is located in these hidden files: webcredentials.ini and webcredentials1.ini.
Published Applications and Assignments are also backed up, and the information is located in this file: Appcontrol.ini.
Before applying the restore, you may need to modify the AppControl.ini file. If you are restoring a backup to another server, or if the server has a different name (and is not within the same domain), it will be necessary to modify the assignment of the accounts from OLD-HOSTNAME/user to NEW-HOSTNAME/user for each deployed application, in order to match the file with the actual Windows accounts.
A "Search / Replace" can do this quickly!
