Websockets is the persistent connection that can be used to receive/send data without sequential order and without http header.
Xhr-polling creates new request with http header and waits for answer with http header, also sequential order.
Doing so, XHR data flow always looks like this:
HTTP_HEADER_REQUEST -> HTTP_HEADER_ANSWER HTTP_HEADER_REQUEST -> HTTP_HEADER_ANSWER and so on
also before the data can be downloaded, it must be requested with HTTP_HEADER, therefore its name: xhr-polling.
Websockets data flow may look like this:
FRAME_DATA_SEND FRAME_DATA_SEND FRAME_DATA_RECEIVE FRAME_DATA_SEND FRAME_DATA_RECEIVE FRAME_DATA_RECEIVE
Also it is random data sending/receiving without special sequential order and without any http header data.
That makes the usage with reverse proxies impossible due to the lack of Websockets support by most known reverse proxies; but half of the xhr transport may work with Apache reverse proxy.
Also see: HTML5 Client: Supported Browsers
