Standard Case
Starting from Terminal Service Plus version 9.20, you can redirect every web request which uses HTTP to the HTTPS secure protocol.
To activate this feature on a server, edit (or create) the file "C:\Program Files (x86)\TSplus\Clients\webserver\settings.bin" and add the following line:
disable_http_only=true
Save the file and restart Terminal Service Plus web servers (AdminTool > Web > Restart Web Servers or reread configuration by accessing http://127.0.0.1/w0j3?settings.bin).
Once this feature is enabled, you can try to browse to the insecure web page at:
http://your-server
and it will automatically redirect your request to the secure Web Portal page at:
https://your-server
Special case: Custom Web Ports
If you are using a specific port to serve HTTPS, then edit the file "C:\Program Files (x86)\TSplus\Clients\webserver\settings.bin" and use the following line instead of the line described above:
disable_http_only="domain.com:4431"
where domain.com is your own server host name and 4431 is your HTTPS custom port.
Save the file and restart Terminal Service Plus web servers (AdminTool > Web > Restart Web Servers).
http://domain.com
https://domain.com:4431
Comment: Even if this is not secure but you wish to disable ssl/https on http port then edit the settings.bin file and add: disable_ssl_on_http=true, save and restart the servers.
Disable http on https
By default it is allowed to access https://my-domain.com, https://my-domain.com:80, http://my-domain.com:443 So it allows http on port 443 or allow https on port 80, it does not have impact on security and makes it easy to fallback to degraded xhr-connection when no websockets support is possible But if wished to disable it, edit the settings.bin file and add the following line:
disable_http_on_https=true
Then restart Terminal Service Plus web servers (AdminTool > Web > Restart Web Servers or reread configuration http://127.0.0.1/w0j3?settings.bin)
HTTPS Enforcement and Free SSL Certificate Validation
Please note that this HTTPS Enforcement feature is fully compatible with our Free SSL Certificate feature.
