Cause:
There is a known issue when attempting to perform remote shadowing on a windows host with TSplus Remote Access version 12 or below.
Solution:
You can use this procedure as a workaround :
- Set the group policy to allow Remote Control without user consent.
- Then you can use the following batch file to shadow or remote control a session:
set /p session="Enter the Session ID to shadow:"
mstsc.exe /shadow:%session% /control /noConsentPrompt /noConsentPrompt
Different method integrated in TSplus :
Add the following line : sessionsmanager-showconsentprompt=no to the [Security] section of the appcontrol.ini file located in C:\Program Files (x86)\TSplus\UserDesktop\files.
