It is possible to achieve better overall performance by reducing the bandwidth used by each remote sessions.
First you can start by reducing the maximum of graphic effects and colors.
If you are connection using the TSplus Connection Client,
- Open a client generator, choose "Disable background and animation for better performances".
- In the display tab, choose 15 bits colors.
If you are connecting using the HTML5 web client,
- open an admin tool \ web portal \ HTML5 client
- check the "Use recommended value" box
- refresh your client browser
- right click on "Computer" and click on properties.
- click on advanced system properties, performances, visual effects, and select "Adjust for best performances".
This setting can be set on client and server side and will enhance graphic performance.
Make sure that your graphic adapter drivers are up to date.
Make sure that your RDP protocols and Windows are up to date.
You can also force the use of the Windows Classic Theme using group policy:
- type gpedit.msc in start search and hit Enter to open the Group PolicyEditor.
- navigate to User Configuration > Administrative Templates > Control Panel > Personalization
- in the right pane, double click on Force a specific visual style or force Windows Classic.
- enable the group policy and leave the field blank to enforce windows classic theme
- reboot
- open a command prompt and run the gpupdate /force command.
