- Locate the TSplus Administrator Tool on your desktop : AdminTool,
- Open the AdminTool and go into the License tile,
- You should see the Serial Number.
Where is my serial number ( also called S/N )? Print
Created by: Marcus Gliesche
Modified on: Fri, 26 Apr, 2019 at 3:45 PM
