We ended generating ".exe" connection clients because the generated ".exe" clients were not signed and as such, detected by anti-viruses as false/positive threats.
Instead we now create ".connect" - flat - files.
Anti-virus programs are happy with it and they don't create issues anymore!
The current solution for now is simple:
You just have to run on your user's PC our signed connection client setup, available here : https://dl-files.com/Setup-ConnectionClient.exe
You will then see that your ".connect" file will work perfectly, the same way the ".exe" files where working before.
For more information please check the following:
- https://www.terminalserviceplus.com/docs/portable-client-generator
- https://www.terminalserviceplus.com/docs/edit-delete-parameters-generated-client
If the above does not satisfies your need, you can also use our previous version of the client generator, which is fully compatible with all of our current version of TSplus and generate .exe files here
http://dl-files.com/ClientGeneratorLegacy.zip
