We ended generating ".exe" connection clients because the generated ".exe" clients were not signed and as such, detected by anti-viruses as false/positive threats.
Instead we now create ".connect" - flat - files.
Anti-virus programs are happy with it and they don't create issues anymore!
The current solution for now is simple:
You just have to run on your user's PC our signed connection client setup, available here : https://dl-files.com/Setup-ConnectionClient.exe
You will then see that your ".connect" file will work perfectly, the same way the ".exe" files where working before.
For more information please check the following:
- https://www.terminalserviceplus.com/docs/portable-client-generator
- https://www.terminalserviceplus.com/docs/edit-delete-parameters-generated-client
