A:
By default HSTS is disbaled because few customers still accessed
http://links
from
https://pages
for same domain so this option is not enabled by default. To enable it follow next steps
1. open/edit(create) with Notepad **\Clients\webserver\settings.bin
2. and add/save as last line
enable_hsts_https=true
3. restart HTML5 via AdmintTool GUI
4. now in **\Clients\webserver\web_log.txt you should see following message Enabled HSTS HTTPS header! indicating that the HSTS was activated.
As in notation above remember, after activating HSTS you won't be able anymore to access http links from your page.
The setting adds as default following header
"Strict-Transport-Security: max-age=31536000; includeSubDomains; preload"
PS: this setting affects only internal webserver, by usage of third part webservers like IIS/Apache refer please to corresponding FAQs.
B:
To activate OCSP stapling you must use at least Java9
oscp_stapling_java9_enabled=true
4. now in **\Clients\webserver\web_log.txt you should see following message OCSP stapling for Java9 enabled! indicating that the OCSP stapling was activated.
