Unfortunately, you cannot use the RemoteApp through the web browser via the plugin with Load Balancing and Reverse Proxy activated.
You will need to use the HTML5 connection mode.
Modified on: Wed, 9 Oct, 2019 at 11:06 AM
Send feedback
