Printer redirection with HTML5 is not supported
Print
Created by: Marcus Gliesche
Modified on: Fri, 26 Apr, 2019 at 4:57 PM
Printer redirection is not supported in Html 5, because of technical limitations that cannot be overcome.
That is why you can only use the Universal Printer when using Html5!
More information about this can be found at this page: Universal Printer documentation
Marcus is the author of this solution article.
Did you find it helpful?
Yes
No
Send feedback Sorry we couldn't be helpful. Help us improve this article with your feedback.
