This is all explained at the end of this video
If you wish to customize the remote control of a session, click start, gpedit.msc
Locate the following GPO : Computer Configuration/Administrative template/Windows Component/Remote Desktop Services/Remote Desktop Session Host/Connections/Set rules for remote control of Remote Desktop Services user sessions
Enable it and choose one of the following options to match your preferences :
How to take control of a remote session Print
Created by: Adrien Carbonne
Modified on: Fri, 16 Nov, 2018 at 10:53 PM
