Sometimes when printing using universal printer the client won't print. A working pdf reader must be installed to solve this issue. If a pdf reader like Adobe is already installed, then you might need to reinstall it.
Open a control panel, click add/remove programs, then select Adobe acrobat and click repair.
Some computers cannot print using Universal Printer Print
Created by: Adrien Carbonne
Modified on: Fri, 16 Nov, 2018 at 10:41 PM
